Civilized Man Textures
I just discovered something about the Civilized Man sweater textrues. I have the add-on Basics textures (which are really great, by the way), but it seems to work only on the long-sleeved version of the sweater. When I tried to put the textures on the version with the pushed-up sleeves, only the bodice part of the sweater will get the texture, but not the sleeves. Has anyone else had this happen? Or were the Basics textures made for only the long-sleeved version? Just wondering.
  • HavosHavos Posts: 5,711
    edited September 2018
    I just checked and I see the same issue. However there is a very simple work around. Select the Sweater, click on the surfaces tab, and then copy the "Bodice" surface to the "Sleeve" surface.
    However this looks like a defect to me and you might want to raise a support ticket. The cause of the problem is that in Sweater 01, the sleeves surface is called "Sleeves" whereas on Sweater 02 they are called "Sleeve" (note the missing s). The first is correct, as "Sleeves" is being used by the material files.
    Another issue I saw is that Sweater 02 is not recognised by Smart Content as having compatible textures.
    Post edited by Havos on
  • melaniemelanie Posts: 807
    Thanks. I think I'll put in a ticket. It needs an update.
