Stephanie 4 and her beach outfits missing?
I just downloaded Stephanie 4 and the beach outfits for Daz. But there is no way I can see them in Daz.
I had this problem with other things I downloaded and suddenly they appeared in the smart content area.
Can anyone help me out?
I would really appreciate it.
Greetings
Marc
    edited August 2013
    Steph will show up in the same place as your V4 stuff, usually under poser formats. Steph 4 is basically a modified V4, although she does load as a separate figure.
    She does require that V4 be already loaded on the computer.
    Post edited by Chohole on
  • edited December 1969
    Many thanks for your post. I am sorry but I still do not get it. I run Daz on Max OSX. Isn't it normal then that all my characters would appear under the content library tab in loading/creating. It does not.
    Can you enlighten me further?
    Regards
    Marc
    Ok, I have left a message for a Mac User to come and help you, but it may take a while as he is in a different time zone to you, and is probably in bed now.
  • TotteTotte Posts: 15,208
    Hello,
    first, not all characters do have "smart content", many old one doesn't.
    If you look in Content-Library -tab, and under Poser Formats -> Figures -> DAZ People you will her and most older Gen 3 and 4 characters there. Remember also that S4 (Stephanie 4) is an add on to Victoria 4 (V4) base and requires that V4 is installed.
    I hope this helps.
    If it doesn't, how did you install her? Via DIM or running installers? Most old installers default to a very wrong path when installing, you need to tell the installer where you have installed your things.
    I am sorry I cannot find it. In Daz Characters there's not even V4 eventhough I downloaded her.
    I think the files are not in the right path. What is the right path? I installed with the latest DIM software.
    Where do the files have to be on a mac?
    Regards and thanks alot for your help.
    Marc
    Follow the instructions below.
    1125 x 693 - 142K
    Hello again
    I want to thank you for your advice. Here my screenshots:
    446 x 444 - 34K
    552 x 541 - 77K
    You nee do click in the [+] on the last screenshot so I can see what directory is mapped there.
    I am sorry. Here it is:
    444 x 445 - 47K
    OK, seems to be installed into /Users/Shared/My DAZ 3D Library, and that is mapped.
    If you use the Content Library Tab, not the smart content (please forget/ignore/pretend you never heard of smart-content when you use Gen-4 or older figures).
    Now, in the Content Library Tab navigate to Poser Formats -> My DAZ 3D Library -> Figures -> DAZ People.
    What do you find there?
    I find the following:
    480 x 673 - 95K
    edited August 2013
    You have Victoria 4 there.
    If you start DIM, go to the Installed Tab, then type Stephanie 4.
    The hold your mouse ptr over the line saying Stephanie Elite Base, and screen shot all (including the small help panel that pops up when you hold the mouse there.
    Like this:
    727 x 670 - 99K
    Post edited by Totte on
    Here the screenshot:
    562 x 516 - 81K
    Ahh!
    That is Stephanie 4 for Genesis (which is a Morph for Genesis, not a Gen-4 figure.
    You will see that if you load a Genesis, then i Shaping, Actor Female there will be a Stephanie 4 slider for Genesis.
    Many thanks for your help.
    All the Best
    Marc
    392 x 682 - 70K
