Does anyone know of or have a genesis 2 base pose/shape for genesis 1?
This has always been a problem with transferring morphs from G1, the transferred morph has the default pose for Genesis, causing problems with all G2 poses.
I assume the solution I need is a G2 Zero pose for G1, so I can save an adjusted version of the morph for transfer. Or, I need a modifying morph on G2 that adjusts the G1 native morphs, the same way you need a G1 head or body morph to restore the proper shape to the imported morph.
Are either of these available out there, somewhere?
  • CybersoxCybersox Posts: 9,924
    Here's a freebie script that tranfers poses back and forth between any of the Genesis figures from 1-8. https://www.sharecg.com/v/89846/browse/8/Script/Daz3d-Pose-Converter-Standalone ;
  • Hmmm. I will take a look at it. When I read it the first time I thought you said "feeble script" so I was not too optimistic! But, I don't have a pose transfer utility that includes Genesis, so I'm happy to hear about this one.
    In the meantime, I was able to accomplish what I needed cycling through a few import/export steps, straightening the  fingers on G2 after transferring the G1 morph. It's not 100%, but it's close enough that posing should not be greatly distorted.
    Thanks, Cybersox!
