Michael 8 Characters
If a character uses Michael 8 will other G8M Characters work as well??
  • LeanaLeana Posts: 13,499
    edited September 2018
    What exactly are you trying to do?
    The texture for the character should work on other G8M figures and vice-versa, and you can combine the character with other G8M morphs.
    However if a character requires M8 it usually means that it uses M8 shape as a part of the morph mix used to create the character, so if you don't use M8 but another shape then the character won't look the same.
    Post edited by Leana on
  • I recently purchased Harrison HD for Michael 8 and was curious if he worked with other G8M characters.  I own Michael 8.
  • Typically, if a character is for Michael 8, then the morph is built off of the Michael 8 base, meaning that for the character to look right, you need both the Michael 8 morph and the character morph.
    If you put Harrison HD into your scene, he'll appear as a Genesis 8 Male character with the morphs for both Michael 8 and Harrison applied.
    I don't understand what you mean by using him with other G8M characters, though.
    If you're asking whether you can use his morphs on a base G8M, then yes, provided you use the Michael 8 morphs as well.
    If you're asking about his textures on a base G8M, then there should be no problem as well. I don't own Harrison, but I've used Michael 8's textures on a base G8M without problems.
    If you're asking something else entirely, then please clarify :)
