Fitting on custom morphs.
GreenBean
Hello,
i use the G8M Base to sculpt a desired morph and most of the times i change how he looks drastically, everything works fine and i add hair/clothes, etc.
after i save and close daz, i re-open the saved model and everything is fitted wrong, the hair is either flying away from the model and most of the clothes are too small or too big.
this never used to happen to me before.
any help is very appreciated.
Thank you :)
Try saving the custom morph as an asset - File>Save As>Support Assets>Morph Asset. It will then load with the figure, so make sure its default value is zero (gear icon on the slider>Parameter Settings) first
Thank you very much!
worked like a charm!
