Problem with install characters for Genesis
velardhgvelardhg Posts: 3
Hi guys ;).. Im new here. And i have problem. I want to install Michael 5. I click : Next > I accept....> Specify an installation path (second option doesn't work too) > Installation path : C:\Users\Komputer\Documents\DAZ 3D\Studio\My Library > Next.... And here is problem. New window : Micheal 5 is add-on for "Genesis" and they must be installed in this same location. Please choose different install location or install requied product..
This message shows up everytime when i want install something for Genesis. What to do? (im on windows 7)
  • Richard HaseltineRichard Haseltine Posts: 111,825
    In your downloads for DAZ Studio you should find one for Genesis Starter Essentials, and another for Genesis 2 Female Starter Essentials. Install that and you will be able to install and use Michael 5.
  • velardhgvelardhg Posts: 3
    In my DAZ3D Install Manager i have already Genesis 2 Female Starter Essential, Genesis 2 Female Starter Essential Poser CF, Genesis Starter Essential and Genesis Starter Essential PoserCF in "Installed" and i still cant instal Michael :/
    If you are using the installer, rather than the DAZ Install Manager, it will insist on being installed to the same folder as the base Genesis - are you? Even if you are, if you've had the installer for a while it's remotely possible the file it uses to spot Genesis has changed enough to confuse it. One fix would be to use the Install Manager for Michael as well.
    Ok now its works ;).. Thanks ;)
