Problems with smooth in models
I need help.
So I don't know why but before that I didn't have this problem. I noticed it today. When I import model to Daz Studio, the "Smooth" option is "on" but the model still looks unsmooth in some parts. I see it in Iray rendering. I don't know exactly what to do I probably did everything to fix it but nothing goes happen.
Post edited by Verewolf on
You mean the surface smoothing option? If so are you sure the unsmoothed areas have weleded geometry? If they are just separate polygons sitting next to each other they won't be smoothed - that works only across connected mesh. If that isn't what you mean, or if that doesn't seem to eb the cause of the problem, please post soem more information on what you are doing - and ideally add some images.
I use Daz Studio 4.10 Pro. I've looked at the "surfaces" option and the Smooth option is still on and Angle is at 180.00%. The problem I am trying to describe is in the attachment.
Please do not create duplicate threads. If you would prefer, we can move your thread to the New User forum.
And moved
Sorry, I missed your reply.
If you go to Tools>Geometry Editor, click on one of the facet polygons, and then prest cmd(Mac)/ctrl(Win) * what area of the mesh is highlighted - just the area clicked, or a wider area? (You then need to seelct another tool, from the Tools menu or the tool bars, to go back to regular posing.)
No, they wouldn't - it's either the model or settings, neither of which will be affected by uninstalling and reinstalling.
What ddi not work? The Geometry Editor Tool? Did you have the model selected? What happend when you followed my steps?
On the disappearning model, go to the Draw Settings pane. What option do you have under Manipulation Draw Style?
