Parenting Two Primitives
For some reason I cannot parent these two lots of primitives together and have them move up and down together. Any help appreciated.Cheers
1920 x 1200 - 99K
Is the telescopic part one object or several? If it's one, is it using a morph to expand?
The telescopic part is one one object that uses several morphs to expand. It is a Poser primitive I found somewhere and imported into DAZ Studio! Cheers
OK, in that case I think you would need to give it a Rigid Follow Node (which might, in its turn, entail making the object a figure) then parent the second cylinder to the Rigid Follow Node.
Sorry I forgot to include morph settings.
I tried the tutorial but it did not work.They use a Genesis Figure.I need a tutorial using morphing props.Cheers
I think the idea was that you can adapt the showen steps to the morphing prop to create a Rigit Follow Node like showen in the video at 4:00.
Actualy there are just a few steps required:
Many thanks. Cheers
