My Genesis is missing in render
LucynskyLucynsky Posts: 64
My girl in green, Vialya, has mysteriously vanished in my scene. Five minutes before that, I was able to render her just fine. I've already recreated her from scratch once. I've tried merging from a known good scene.
This one's a hair-puller for me. I checked on the opacity maps under surfaces, and the eyeballs under Scene. I've checked under Parameters, and the "Visible in Render" is on.
Halp please!
600 x 480 - 510K
  • frank0314frank0314 Posts: 15,116
    Which app are you using, DAZ Studio or Poser? Have you restated recently?, Are you loading a figure or applying a preset?
  • LucynskyLucynsky Posts: 64
    Thank you.
    I'm using Daz 4.6. I have restarted, and rebooted. Both times, same results.
    I have loaded genesis and recreated my green girl from scratch: Load Genesis, use Briallen (never had this issue before), clothe/pose her, shift blaster effect to match the pistol. Spot render.... dang it. Not there. It's really weird because my red girl is still there.
  • JaderailJaderail Posts: 0
    So the figure shows in the Scene tree, is selectable but just does not Render? Do you by any chance have a Shader on the figure? Maybe Uber?
    I'll try this in the morning. Thanks! I know the outfit does. I'm pretty sure the skin texture is HSS.
    What I was getting at was Uber has a fantom setting... if on the figure is not rendered just the shadow is.
    Hrmm, can make some creepy renders with that. >.>
    But back to this. She does have omUbersurface on her. Checked the Fantom settings and they're off. Turned them on. Rendered. Then turned them off. Newp.
    Piddle, and Merging just that figure set up into the scene also goes blank? I'm at my ropes end.
    It's really strange. I put in the regular textures without the HSS, and it does the same. No girl.
    Think I'll take her out, render and post the log for grins and gidgity.
    we were just thinking of the log with it in the scene. Could offer so answers.
    Ok, will attach both render and log.
    Log: Sorry for the wall of text
    *** Scene Cleared ***
    F:/daz content stuff/data/DAZ
    3D/Genesis/Base/Morphs/Valandar/Reptillian/MCMStegoEyesClosedR.dsf (65,4): Unexpected
    character
    WARNING: shapes\dzfacetmesh.cpp(2570): Index out of range in DzFacetMesh::getNormal()
    WARNING: fileinput\dzassetdaz.cpp(5127): Could not find target property for formula:
    Genesis:/data/DAZ 3D/Genesis/Base/Genesis.dsf#Genesis?scale/general in file :
    /data/Michelle/Hair/PH Wild/PHWild.dsf#PHWild
    Genesis:/data/DAZ 3D/Genesis/Base/Genesis.dsf#Genesis?scale/x in file :
    Genesis:/data/DAZ 3D/Genesis/Base/Genesis.dsf#Genesis?scale/y in file :
    Genesis:/data/DAZ 3D/Genesis/Base/Genesis.dsf#Genesis?scale/z in file :
    WARNING: fileinput\dzassetdaz.cpp(5307): Unsupported formula: /data/DAZ 3D/SteamPunk
    Wilde/SpWilde_Boots/SpWilde_Boots.dsf#SpWilde_Boots
    Genesis:/data/DAZ 3D/Genesis/Base/Genesis.dsf#Genesis?scale/general in file : /data/DAZ
    3D/SteamPunk Wilde/SpWilde_Boots/SpWilde_Boots.dsf#SpWilde_Boots
    Genesis:/data/DAZ 3D/Genesis/Base/Genesis.dsf#Genesis?scale/x in file : /data/DAZ
    Genesis:/data/DAZ 3D/Genesis/Base/Genesis.dsf#Genesis?scale/y in file : /data/DAZ
    Genesis:/data/DAZ 3D/Genesis/Base/Genesis.dsf#Genesis?scale/z in file : /data/DAZ
    WARNING: fileinput\dzassetdaz.cpp(5069): Could not find output property for formula:
    Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Creature
    Creator/FBMStocky.dsf#FBMStocky?value in file : /data/DAZ
    3D/Genesis/Base/Morphs/RawArt/Raw_Dwarfology/Raw_Dwarf-Body-M7.dsf
    Creator/PBMNeckGone.dsf#PBMNeckGone?value in file : /data/DAZ
    3D/Genesis/Base/Morphs/RawArt/Raw_Dwarfology/Raw_Dwarf-Body-M6.dsf
    3D/Genesis/Base/Morphs/RawArt/Raw_Dwarfology/Raw_Dwarf-Body-M5.dsf
    Creator/PBMHandsMonstrous.dsf#PBMHandsMonstrous?value in file : /data/DAZ
    3D/Genesis/Base/Morphs/RawArt/Raw_Dwarfology/Raw_Dwarf-Body-M4.dsf
    3D/Genesis/Base/Morphs/RawArt/Raw_Dwarfology/Raw_Dwarf-Body-M2.dsf
    3D/Genesis/Base/Morphs/RawArt/Raw_Dwarfology/Raw_Dwarf-Body-M1.dsf
    3D/Genesis/Base/Morphs/RawArt/Raw_Dwarfology/Raw_Dwarf-Body-F7.dsf
    3D/Genesis/Base/Morphs/RawArt/Raw_Dwarfology/Raw_Dwarf-Body-F6.dsf
    3D/Genesis/Base/Morphs/RawArt/Raw_Dwarfology/Raw_Dwarf-Body-F5.dsf
    3D/Genesis/Base/Morphs/RawArt/Raw_Dwarfology/Raw_Dwarf-Body-F4.dsf
    3D/Genesis/Base/Morphs/RawArt/Raw_Dwarfology/Raw_Dwarf-Body-F2.dsf
    Creator/PBMBelly.dsf#PBMBelly?value in file : /data/DAZ
    3D/Genesis/Base/Morphs/RawArt/Raw_Dwarfology/Raw_Dwarf-Body-F1.dsf
    WARNING: fileinput\dzassetdaz.cpp(5301): Duplicate formula found linking Value &
    CTRLFlirtingMasculineR in /data/DAZ 3D/Genesis/Base/Morphs/DAZ
    3D/Expressions/CTRLFlirtingMasculineR.dsf.
    CTRLFlirtingMasculineL in /data/DAZ 3D/Genesis/Base/Morphs/DAZ
    3D/Expressions/CTRLFlirtingMasculineL.dsf.
    3D/YoungTeens/FhMJulieHead.dsf#FhMJulieHead?value in file : /data/DAZ
    3D/Genesis/Base/Morphs/DAZ 3D/YoungTeens/MCMJulieHdUpperEyeLidDownR.dsf
    3D/Genesis/Base/Morphs/DAZ 3D/YoungTeens/MCMJulieHdUpperEyeLidDownL.dsf
    Creator/FBMOgre.dsf#FBMOgre?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ
    3D/Creature Creator/MCMOgreEyesClosedRight.dsf
    3D/Creature Creator/MCMOgreEyesClosedLeft.dsf
    Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Creature Creator/FBMHag.dsf#FBMHag?
    value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Creature
    Creator/MCMHagEyesClosedR.dsf
    Creator/MCMHagEyesClosedL.dsf
    Creator/FBMFaerie.dsf#FBMFaerie?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ
    3D/Creature Creator/MCMFaerieEyesClosedR.dsf
    3D/Creature Creator/MCMFaerieEyesClosedL.dsf
    Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Creature Creator/FBMExo.dsf#FBMExo?
    Creator/MCMExoEyesClosedR.dsf
    Creator/MCMExoEyesClosedL.dsf
    Loaded Morph Deltas in 0 min 0.0 sec.
    Loaded file: PHMShock.dsf
    Loaded file: MCMJulieThumbFistR.dsf
    Loaded file: PBMDeltoidFlexR.dsf
    Loaded file: Briallen Body.dsf
    File loaded in 1 min 29.0 sec.
    Loaded file: Vialya and Seki 03-merge vi back in.duf
    Loaded file: LongerBlast_LongerBlast_8.dsf
    Loaded file: PHMBrowInnerDownL.dsf
    Loaded file: WidowPeak.dsf
    Loaded file: PonytailHigh.dsf
    Loaded file: Under-Breast.dsf
    Loaded file: Offset.dsf
    Loaded file: HighHeel2.dsf
    Ran tdlmake on image F:/daz content
    stuff/Runtime/Textures/TechStaves/valStavesBlastEffectB.jpg
    stuff/Runtime/Textures/TechStaves/valStavesBlastEffect.jpg
    stuff/Runtime/textures/DAZ/Characters/GenesisBodysuit/reflect 1.jpg
    Ran tdlmake on image F:/daz content stuff/Runtime/Textures/DAZ Clothing/M4/Major
    Cache/mc_handgun_bum.jpg
    Cache/mc_handgun.jpg
    stuff/Runtime/Textures/xilia78/Briallen/Briallen_LimbsB.jpg
    stuff/Runtime/Textures/xilia78/Briallen/Briallen_TorsoS.jpg
    stuff/Runtime/Textures/xilia78/Briallen/Briallen_LimbsS.jpg
    stuff/Runtime/Textures/xilia78/Briallen/Briallen_Limbs.jpg
    stuff/Runtime/Textures/xilia78/Briallen/Briallen_Lashes_1.jpg
    stuff/Runtime/Textures/xilia78/Briallen/Briallen_LimbsTL.jpg
    stuff/Runtime/Textures/xilia78/Briallen/Briallen_LimbsED.jpg
    stuff/Runtime/Textures/xilia78/Briallen/BriallenSclera.jpg
    stuff/Runtime/Textures/xilia78/Briallen/Briallen_LimbsSD.jpg
    stuff/Runtime/Textures/xilia78/Briallen/BriallenEyesBump.jpg
    stuff/Runtime/Textures/xilia78/Briallen/Briallen_Corneatr2.jpg
    stuff/Runtime/Textures/xilia78/Briallen/Briallen_Eye1.jpg
    stuff/Runtime/Textures/xilia78/Briallen/Briallen_Teeth.jpg
    stuff/Runtime/Textures/xilia78/Briallen/Briallen_TeethB.jpg
    stuff/Runtime/Textures/xilia78/Briallen/Briallen_TeethS.jpg
    stuff/Runtime/Textures/xilia78/Briallen/Briallen_TorsoTL.jpg
    stuff/Runtime/Textures/xilia78/Briallen/Briallen_torsoB.jpg
    stuff/Runtime/Textures/xilia78/Briallen/Briallen_Torso.jpg
    stuff/Runtime/Textures/xilia78/Briallen/Briallen_TorsoSD.jpg
    stuff/Runtime/Textures/xilia78/Briallen/Briallen_Face.jpg
    stuff/Runtime/Textures/xilia78/Briallen/Briallen_TorsoED.jpg
    stuff/Runtime/Textures/xilia78/Briallen/Briallen_FaceB.jpg
    stuff/Runtime/Textures/xilia78/Briallen/Briallen_FaceS.jpg
    stuff/Runtime/textures/DAZ/Characters/GenesisBodysuit/DAZ Glitter.jpg
    stuff/Runtime/Textures/xilia78/Briallen/Briallen_FaceTL.jpg
    stuff/Runtime/textures/DAZ/Characters/GenesisBodysuit/OM_KHPark_EnvRefl.jpg
    stuff/Runtime/Textures/Michelle/PHWild/ValPHWildC_T02.jpg
    stuff/Runtime/Textures/Michelle/PHWild/ValPHWildC_Spec.jpg
    stuff/Runtime/Textures/xilia78/Briallen/Briallen_FaceSD.jpg
    stuff/Runtime/Textures/xilia78/Briallen/Briallen_FaceED.jpg
    stuff/Runtime/Textures/Michelle/PHWild/ValPHWildC_Tr.jpg
    stuff/Runtime/Textures/Michelle/PHWild/ValPHWildC_Bump.jpg
    stuff/Runtime/Textures/Michelle/PHWild/ValPHWildH_T02.jpg
    stuff/Runtime/Textures/Michelle/PHWild/ValPHWildH_Spec.jpg
    stuff/Runtime/Textures/Michelle/PHWild/ValPHWildH_Tr.jpg
    stuff/Runtime/Textures/Michelle/PHWild/ValPHWildH_Bump.jpg
    Ran tdlmake on image F:/daz content stuff/Runtime/Textures/SpWilde/MkBoots.jpg
    Rendering image
    WARNING: UberEnvironment2 2: The light 'Color' must be mapped in order to use 'Directional
    Shadows'; using Soft Shadows.
    WARNING: QColor::setHsv: HSV parameters out of range
    Compiled C:/Users/judyv/AppData/Roaming/DAZ 3D/Studio4/shaders/brickyard/{2ddce9fb-cafb-
    4266-ab32-121b3625dde4}/shader_Surface.sdl...
    Created RenderCacheBlock
    Saved image: F:\USERS\judyv\AppData\Roaming\DAZ 3D\Studio4\temp\render\r.png
    Finished Rendering
    Total Rendering Time: 4 minutes 43.96 seconds
    Saved image: F:\USERS\judyv\AppData\Roaming\DAZ 3D\Studio4\temp\RenderAlbumTmp\Render 1.jpg
    Saved image: F:\USERS\judyv\Desktop\daz saves\renders\vialya the invisible girl 01.jpg
    625 x 500 - 82K
    I can actually see just a little bit of her head as though the opacity was really low.
    edited August 2013
    The bosses think one of your Morphs Reptilian by Valander is errored. It shows as failing. Try uninstalling it and then test your figure.
    Hold off on that more talking on it.
    EDIT: What is your Library Path and How did you install your Content?
    Post edited by Jaderail on
  • Richard HaseltineRichard Haseltine Posts: 111,984
    it also looks as if you have old versions of a couple of morphs - Raw's Dwarfology and the Genesis Evolution Expressions, though unless you've edited the log to reduce it there should be other morphs from the sets throwing the error. Most of the other morph-related messages are just that you don't have a morph set (the Creature Creator morphs) for which one of your other sets has correction morphs - those will be inactive as a result, so they will not be a problem.
    There was a lot more that I cut out while trying to concentrate on the render errors. I think Daz is loading the morphs in ahead of time in case I want to use them. Do you suppose something in there is botching it up? I'm trying to keep everything off my boot drive (c:) and on my data drive (f:).
    My content is F:\daz content stuff
    My daz3d folder should be F:\programs\daz3d
    I am using the DIM software. Frankly, it's lurvely. I don't miss the old inflicting the exe files then clickclickclickclick.
    The only morph I'm using is the one that comes with Briallen. Earth girls are easy, at least. *grin*
