Hedges in C8P, are they possible?
Turk_WLFTurk_WLF Posts: 177
edited August 2013 in Carrara Discussion
I need some hedges for the building/scene that I’m working on. I think have seen some done for a contest on here but I need the more boxer type such as those in the link below.
http://schrocklawnscapes.com/wp-content/uploads/2013/02/hedge.jpg
If possible I would like a guide on how to do them so I can make them.
Thanks,
Post edited by Turk_WLF on
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,830
    edited August 2013
    yes http://www.youtube.com/watch?v=8qCV714cT4w
    answer, surface replicators!
    I made a vertex maze object and replicated my plant on it
    (to be fair some of this video, the first bit and end was my plant exported from Carrara as an obj to iClone and duplicated)
  • VarselVarsel Posts: 574
    Wendy beat me to it while I was rendering out the pictures.....:lol:
    Create a branch.
    Create a vertex object in the shape of the hedge.
    Replicate the branch on the vertex object.
    Hide the vertex object....
    I made a fairly large branch. so I had to uncheck the Align objects to normal, but with a Z (blue) rotation on 180 deg.
    The branch was made in the plant modeler..
    800 x 600 - 252K
    800 x 600 - 386K
  • Turk_WLFTurk_WLF Posts: 177
    Varsel,
    That's super close to what I want but some reason I can't get the branch to come out with a "flatten" top with Wendy's & your help I got an untrimmed hedge, & I would a trimmed hedge closer to that your hedge.
    It might be the shape of the branch/tree.
    I did a quicky...
    A couple of thing that I did notice...
    Uncheck the tip mark both under the trunk and expert tab.
    Increase the leaf size. This is a branch and not a tree. You could afterwards adjust the size in the assembly room.
    Adjust the leaf orientation so the leafs are pointing more downwards. It gives a tigher look.
    Set the tree shape to - pruning to cylindrical or inverse conical.
    Replicate enough branches. In this example there are 800 replications...
    1414 x 624 - 343K
    834 x 761 - 154K
    800 x 600 - 167K
