How disable the "smoothing" of genesis (with resolution base and subdivison 0) ?
hi
When you move a part of genesis (bend arm, rotate leg, ....), the curves are less strong and when you hold on the left button the body seems smoothing.
I didn t find the parametre which command this effect.
Thanks
If you're talking about when you're using active pose the mesh seems to "shrink" until you let go, I do not believe that can be changed.
Thanks for reply.
Open the Tool Settings Pane and select the universal tool. Under the "During Manipulation" section you will see an option for SubDivision. Change it to Persistent (on). This will keep SubDivision on when posing. Keep in mind that this is very resource intensive. This is the reason it is set to Delayed (off) by default.
Oh wow I stand corrected. TIL!
