Girl 6 not working
MouserMouser Posts: 775
Not sure what's wrong, I've copied the Data, People & Runtime content but it looks as if Girl 6 isn't going through DSON.
i.e. the DSON translation message doesn't appear like the other content does.
The other Genesis 1&2 stuff works fine only Girl 6 isn't working?
  • Richard HaseltineRichard Haseltine Posts: 111,841
    In Poser? Are you saying you don't get the progress bar when you try to load G6, and that the figure doesn't load?
  • MouserMouser Posts: 775
    Good point, I reloaded the same models and didn't blink,Girl 6 did display the DSON progress bar but unlike the other models the progress bar completed very fast, it was over in a fraction of the normal time.
    So DSON is picking up G6 but due to the speed it is completing I suspect its actualy not doing anything.
    The problem is there is no error message, everything is as normal except the DSON progress bar completes quikly then nothing is loaded?
    I hope that made sense
    PS
    PoserPro 2012 64bit
    Windows 7 64bit
    Are you sure the file you are loading isn't something like a materials preset, which won't load a figure, rather than a character preset, which will?
    I'm trying to load the Girl 6 figure.
    Figure->DAZ People->Girl 6
    No figure is in the view screen although at the top left the figure name & components (body etc) are listed.
    In the Parameters window/panel there are some items listed General, Actor, Other & Transform.
    I then checked the Properties panel which has the option Visible ticked.
    Not sure what to make of this, so I'm going to download the installers again and try and reinstall again.
    Noticed my version of DSON was not up to date so installed latest, no change.
    Okay now V6 doesn't work either, I've checked the Data, People & Runtime and the files are there so why doesn't Genesis 2 content work?
    I have the latest version of DSON installed and Everything else works okay.
    This is getting worse not better the more up to date my system is, that makes no sense.
    Okay, a full reinstall of Genesis 2 content.
    Genesis 2 Essesntials
    V6
    Girl6
    Few, now it works.
    Not sure how but something got corrupted somewhere in the install steps for Girl 6.
    Thank god for backups.
