[resolved]Hexagon partial morph to DAZStudio4
Sylva1nSylva1n Posts: 0
edited June 2012 in Daz Studio Discussion
Hello,
I understood how to create a morph with Hexagon 2.5 and impoting it into DAZStudio 4.
However, this process creates a global morph.
How can I create only a face morph?
best regards,
Sylvain
Post edited by Sylva1n on
  • Richard HaseltineRichard Haseltine Posts: 111,002
    For which figure? Genesis doesn't support partial morphs, there's only one geometry (which belongs to the root node). It doesn't, however, matter - a morph will change only those bits of the mesh you alter, it won't stop morphs on the unchanged parts from working normally (nor indeed will it stop morphs on the parts it does affect) - and you can place the controller on whichever body part you like if the root is not a logical or convenient location.
  • Sylva1nSylva1n Posts: 0
    What do you mean by
    thanks
    When loading a morph in you should be able to choose where the control is placed. You can also move it using the Property Editor.
    I use the bridge between DAZStudio and Hexagon.
    I don't see how to choose where the control is placed.
    Is it a Morph Loader feature?
    thanks
    I think you need to go to Edit>Preferences>Interface and under Hexagon Bridge enable the Advacned interface option, that will give you extra options.
    Perfect!
