My Basic Child has Woman Curves
DekeDeke Posts: 1,636
I don't use Daz a lot, but would like to use it more, yet when I start a new file and load what I think is a basic Genesis figure, it comes shaped with womanly curves. Even the basic child appears with boobs and hips. Why won't this load in a basic Genesis?
Thanks for any advice.
  • JaderailJaderail Posts: 0
    There is one FREE morph set that will alter your figure. If you have it installed it will cause it. I do not have a link as I might forget and install it too.
    This is due to a bug with certain morphs (usually freebies) and what's happening is it's setting Genesis' Female morph to maximum, meaning that you start with a female figure. Any subsequent morphs, such as Basic Child, will also be blended with the female which is why you get big breasted children. I'm fairly certain that in the majority of cases you can simply zero out the Basic Female figure in the Shaping tab to get things back to normal.
  • DekeDeke Posts: 1,636
    Thanks for the help. The Basic Woman in Shaping is already at 0. I can open parameters and take off the restraints and that enabled me to reduce those settings to less than zero. That seems to do the trick.
