Plugins can't find Daz installation path and won't install
I just installed Daz Studio 4.6. When I try to install the plugins ( FBX export, Goz etc.) they all say they can't find the
Daz installation path. I had 4.5 installed, uninstalled that and installed 4.6 with the default values. The plugins can't find the path.
If I remember right, the path is kept is some configuration file in the users folder. Could this be the problem?
Post edited by shawnlau_8905c7c970 on
  • edited December 1969
    I found the dazinstall.ini file in Users/Me/AppData/Roaming/Daz 3d
    It correctly lists the the install location as C:\Program Files\DAZ 3D\DAZStudio4.
    Why can't the plugins find the installation path?
  • fixmypcmikefixmypcmike Posts: 19,707
    Are you installing with stand-alone installers or DIM?
    I'm installing them as stand alone.
  • edited August 2013
    I think I found the problem. When I put Daz 4.6 in my cart, the site is placeing old DS3 plugins in the package instead of DS4 plugins. How can I get the DS4 plugins?
    958 x 971 - 175K
    And then again, I think maybe FBX exporter and the Texture atlas come pre- installed. Could that be the case? I got Goz to install.
    Yes, FBX Exporter and Texture Atlas are built into the main DS4.6 installer.
    Thats was it:) And FBX exporter works a lot better than the old one :)
