Beginner problem with lights
I’m hoping someone can help with my problem. So far I’ve been doing renders with just the head lamp, it usually gives good results and I can see the scene quite clearly in the Daz viewport to make changes to it etc.
Now I want to use the lighting that comes with various products, particularly to avoid the washout in renders that sometimes happens with the headlamp (for example if I have a character that is wearing white clothes). So I use the lighting, and the resultant render is great, but when the lighting is on the scene in my viewport in Daz goes quite dark and I cannot see any of the detail in it to make changes. Is there some way I can use this lighting but still see the scene in my viewport without the darkness that the lighting causes?
Thanks for any help you can give.
Use CTRL+L to switch on the "posing lights".
Many thanks Bee, so easy! Where did you find out stuff like this?
By asking in the forum, or rather, this particular piece of information, by following a thread where it was mentioned over in the Commons section.
