Genesis 3 UV Swap: Male and Female Base
Hi to everyone!
Does anybody know how to use the Genesis 3 UV Swap: Male and Female Base?
Because when I try, for example, to double click on the "Genesis 3 Female UV Preset", I can see the figure glitches a little bit and nothing else happens.
Can you give me a suggestion? Or a document?
I would like to apply a G3F Skin --> G3M Skin.
Thanks and regards,
Ennio
  • vwranglervwrangler Posts: 5,045
    Apply your G3F texture to G3M. If it doesn't align seamlessly at that point -- some will, some may not -- select your figure, then double click the preset, and it should align correctly. If that doesn't work, then go to the surfaces tab, select all surfaces, scroll down to the bottom of the settings (it may be somewhere else in the list, depending on the shader), and under the "UV Set" select the "Base Female" option from the dropdown in that part. (It may be listed as "Genesis 3 Base Female", depending; I'm not at that computer at the moment.)
    If none of that works, then you may have a G3F character that uses one of the (few) dozen or so different UV maps that Daz issued during the Genesis 3 generation, and the UV swap will only work for Base Female and Base Male.
  • Hi Vwrangler,
    thanks for the quick answer. Because of this I understood that I was on the right path and I was able to apply a texture created with Skin Builder.
    Thanks and regards,
    Ennio
