Gen X Pane missing
Hi guys,
I wanted to use Gen X today to convert a M4 figure to G3M but my Gen X pane disappeared. I can´t find it anywhere. Uninstalled it with DIM and reinstalled. Still not showing up as Window/Panes/Gen X as it used to. I have successfully worked with it numerous times in the past.
I have recently upgraded to 4.10 and this would have been my first time using it since the upgrade. Don´t know if this is somehow related though.
    Have you actually installed it? Check Help>About Installed Plugins. You may need to add the serial number.
  • hasnhasn Posts: 4
    That was quick. Hi fastbike1 and thanks for trying to help me out.
    The problem seems to be that I also still have the 4.9 version running on my system. And Gen X is registered and installed on that version. So when I started the older 4.9 it had Gen X installed and working as always. I converted the figure as planned and I can also use it on the upgraded 4.10 version. As a workaround good enough for the moment as I rarely use it anymore.
    That also explains why Gen X is installed referring to the DIM but not showing up in the Help/About Installed Plugins menu in the 4.10 version.
