Install Manager v1.0.1.81 (Update problem)
lannabullslannabulls Posts: 0
edited August 2013 in Daz Studio Discussion
My Install Manager 1.0.1.81 version does not work properly.
I install it, download my purchased contents, install them, no problem at all, everything is working fine.
Yesterday I lunch Install Manager and I receive a worning about a new update, a window tells me to download the update, etc, I follow it so I run the update, the download end, it supposes to turn off Install Manager, Install the update, again as window suggests. On the contrary the download ends and that is it ,my install manager disapears, it is not in my pc anymore (my os is windows 7 64 bit, Install Manager is 32 bit so the default isntallation is in "C>program files (x86)>DAZ 3D>DAZ3DIM1")
I reboot pc, Install Manager is still missing. I must download and reinstall it again, doing that it works fine however the problem is that I get another worning about a new update, if I run it same story as told above.
Some of you guys are encountering the same problem?
Thanks a lot!
Post edited by lannabulls on
  • Richard HaseltineRichard Haseltine Posts: 112,009
    The update worked for me - my first suspicion would be your security software. Did you get the Windows prompt to allow the update to install, or did it stop before that point? What anti-virus etc. are you using?
  • fixmypcmikefixmypcmike Posts: 19,741
    Do you have dual video cards (NVIDIA + Intel)? Try going to Windows\SysWOW64 (you'll need hidden and system folders showing) and rename nvinit.dll to nvinit.bak
