Install Manager - Could not find install application
SolnoidSolnoid Posts: 0
Ok, did a bit of searching here and didn't find anyone with my exact issue, so here it is:
I've made sure to add Daz Studio 4.5+ to the Applications tab under settings, but I'm still unable to get a few things to load. Specifically, trying to install the Dynamic Clothing plugin using the Install Manager kicks back the following from the Log:
WARNING: QAccessibleWidget::rect: This implementation does not support subelements! (ID 6 unknown for QWidget)
Could not find install application for: DAZ Studio 4.x Public Build (64-bit)
Product failed check, moving to next product : IM00016591-02_DynamicClothingControlforDAZStudio45Win64bitPublicBuild.zip
Install Queue finished in 0 min 0.0 sec.
And, technically, it's right. I don't have a path to DAZ Studio 4.x Public Build (64-bit), it's Daz Studio 4.5+ (64-Bit). There's no option to add DAZ Studio 4.x Public Build (64-bit) as a path (i.e., no Public Build option within DIM).
However, all of the other plugins I've used the DIM to install have worked (expect the ones reliant upon Poser 9 and the Photoshop > CS2 requirement such as the bridge, don't have those).
I'm assuming Public Build has something to do with Beta releases or some such? Hence why it doesn't want to install?
---Sarge
  • Richard HaseltineRichard Haseltine Posts: 111,612
    Yes, Public Build means the new beta.
  • SolnoidSolnoid Posts: 0
    Thanks. Since I don't usually mess with the betas, I can safely ignore it.
    That being said, is there a provision within DIM to help make the beta plugins install if you also have the beta of studio installed? If so, how does one go about it?
    ---Sarge
    ---Sarge
    In DIM, plugins for the beta are separate items from the same plugins for the general release -- in either case, they only install to the version they are meant for.
