A VRAM oddity
Second Technician Rimmer
I created a scene for rendering which, when I loaded it and rendered it on my gtx970 (4.xGB of Vram), gave me a reading of close 4.00 gb of vram used.
I then passed the same scene, repackaged thanks to a script, to a friend who owns a gtx 1070TI (8GB of VRAM) and he rendered it. His reading was... almost 8GB of Vram used.
Shouldn't the same scene, using the same textures and settings in every regard, use the same amount of vram on both video boards?
How were you getting the usage figures? Whereever it was, were you subtracting the before rendering value from the during value to make sure it was just the amount used for rendering that was being measured? Did you friend have another render window left open?
@second.technician.rimmer_9571136c47
Did you check that the texture compression settings are the same? They are sort of a hidden parameter that users typically set once then forget.
Another question would be how your friend was getting the Vram info? All users are not equially versed in obtaining/understanding the info.
There's a bunch of reasons why that might happen, including:
We both used GPU-Z to track how much vram gets busy in the end.What we were measuring was how much vram was used overal, including
prerender and after the textures got loaded. His DS is kinda "out of the box". He didn't touch the compression settings and neither did I on my side.
From what I could see, his vram use was around 200MB before he started the render and once the xture loaded up, it jumped immediately at 7.5GB.
Actually, regarding the used Vram, is there even a way to have DS free some of it once a render is finished or even interrupted? :)
As long as the render manages to stay on the GPU closing the render window will free up the memory, more or less. If the render runs out of RAM and drops to CPU then you will at least have to close and restart DS and may need to restart the OS.
I see... I didn't know the render could just "drop out" of vram and go for CPU on its own. I more or less expected the whole thing to crash if the vram was overwhelmend while my settings were on GPU only. That's interesting, thank you all for your guidance :)
