SG Copy Pose Animated Script issue
I posted this in the original scripts thread but it has not been active for a while so I thought that this might be a problem that is common to scripts so I posted here as well. I have an issue now that I did not get before when using the SG Copy Pose Animated Script. While attempting to transfer from Victoria 6 to Victoria 7 or from V4 to G3, or V5 to V7. I get the following message .
general\dzscript.cpp(658): Unhandled errorwhile executing script. QscriptEngine::popContext()doesn't match with push Context()
then, the script stops after converting about 200 frames and then V7 (G3 when used with v4 to G3) is suddenly placed to the side of V6 and has all the upper body muscularity morphs applied. I have used this script before many times to convert from V6 to V7 with animations exceeding 6000 plus frames and it worked fine. The only difference I can think of that I have now is that I istalled muscularity morphs for G8 recently. Any help would be appreciated.
Kwan
closing this thread as your query has been answered in this thread
https://www.daz3d.com/forums/discussion/comment/3895911/#Comment_3895911
