Save with UV Set
Esteisy
Good afternoon to everyone,
I'm using a Genesis2 Female character with a Victoria 4 UV set, whenever I load the scene it turns the UV Set to Base Female.
This problem happens at Daz Studio & Hexagon.
Any idea?
Thanks.
Maybe your scene file got corrupted somehow.
To test you could create a new scene, load a fresh G2F from the content library, set the UV to V4 and save the scene. Restart DazStudio and load the scene file again to see if its still set to the V4 UV. If this works you know its not the G2F or the V4 UV asset having problems.
There are options to save what you have created in the original scene to apply it to a fresh G2F loaded from the content library maybe in the same or another scene.
With your original scene loaded you can save a character preset for shaping and textures and with G2F still selected a wearable preset that includes everything fitted and parented to the figure to the library, also save the pose/animation with a pose preset. Now delete the G2F figure and all fitted/parented items, then load a new G2F and apply all saved presets from before.
Hi, I have had an issue like this in the past. Did you use smart content to apply the UV or did you navigate to the UV via surfaces? One thing you can do to make your life easier if it continues is once the UV is applied you can "File" then save as "Hierarchal Material", it will save the applied UV's for the figure into your "My Library" presets under "Hierarchal Materials" so you can one click re-apply the UV from the "My Library" found in "Content Library".
I have assigned the materials directly from the surface tab, and then assigned them as V4.
Thank you so much for your answers, I will try to save it as Hierachal Mterial.
