Bounty Huntsmen Outift Errors
Anyone else getting issues with this outfit installed by Daz Connect? Same issue as with that one outfit from the Zelara bundle, no icons and won't load. Why is this stuff always broken? Does anyone test these things? I mean, I'm willing to test things for a discount...wait...I'm doing it for free now......
Just kidding, no offense meant, but I am wondering if it's just me, or if I should file another ticket for this one now.
Log file says this about it
C:/Users/Brimstone Omega/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_54319/people/genesis 8 male/clothing/bounty hunter scifi/bounty top male.duf (1,1): Syntax error - expected '{' or '[
1920 x 1080 - 162K
  • I have the same problem with this product. Also happens with DIM as well.
  • Cris PalominoCris Palomino Posts: 12,959
    Have you contacted Daz with a ticket?  https://www.daz3d.com/help/help-contact-us
  • Have you contacted Daz with a ticket?  https://www.daz3d.com/help/help-contact-us
    Not yet, but I'm starting to feel like I bother those kind people quite a bit lately. It's just kind of disappointing when you buy something and it's broken. Again, and again. It wouldn't bother me if there was a mistake or two with like having an icon tied to a different material or some other mistake, but not being able to even install something the way it is advertised to be able to install is a little different then just a mistake. Mistakes happen, and I know this is also just a mistake, I'm not upset because I know it will be fixed at some point, but it does happen quite frequently it seams, hence my beginning to wonder if things get tested.  It only takes a few second to install something to see if it works.....
  • If it was just Connect I'd suspect a glitch in authenticating and decrypting the download files, but if it's affecting DIM too (in the same way) that might indicate a packing issue. Please uninstall, rstart DS, and try installing again - if it still fails, please try DIM.
  • Trying again, bot ways, still failed.
    However downloading it manually and running the C:\Users\User\Downloads\IM00054319-01_BountyHuntsmanOutfitforGenesis8Males.zip\Content\People\Genesis 8 Male\Clothing\Bounty Hunter Scifi Bounty !Load All.duf  (DSON User File) opens up DAZ studio and brings in the clothing set.
  • DamselDamsel Posts: 406
    I'm having the same issue. I downloaded it with Connect, got no icons. Downloaded it with DIM, got icons, but when I tried to load it, it gave me an error message. Dragged it in and got this. It keeps referring me to the log file, which I can't seem to find. Sigh. Where is that? Checked the user manual; no log file found. Argh.  I like this outfit; I want to use it. What gives? Opened a tech support ticket.  Grr.
    953 x 732 - 162K
    By the way, I uninstalled and reinstalled it four times.
    I tried going into my content file and hitting the load all icon, and it came up as a bunch of boxes again.  This is kinda annoying. Something's got to be missing out of this file. Where the hell is the log file?
  • MadaMada Posts: 2,065
    The log file is under Help -> troubleshooting -> Log file. Its working fine on my computer and I see people making renders with it so I'm not quite sure what the problem could be, please submit a support ticket so it can be investigated thank you :)
    Thanks, Mada. I saved the log file, but it's still not clear to me what the problem is. I've submitted a support ticket. I wonder if it has something to do with the fact that I don't own Duane. But I was under the impression that the clothes would work without him.
    The log file says C:/Users/User/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_54319/people/genesis 8 male/clothing/bounty hunter scifi/bounty !load all dwayne.duf (1,1): Syntax error - expected '{' or '['
    2018-08-27 16:38:02.057 Error reading file, see log for more details.
  • barbultbarbult Posts: 27,474
    That looks suspiciously like the error I get with several other products that I installed with Daz Connect. Is that how you installed? If so, it you uninstall with Daz Connect and install with Daz Install Manager (DIM), I bet it will work for you.
    Something has been going wrong with some products in Daz Connect. Submitting a help request is the right thing to do so they can fix the product files for Daz Connect, if that is indeed your problem.
    Thanks! I’ll try it. I tried reinstalling it manually and with DIM, but I’m still getting the code.
    If you ever installed it with Daz Connect, you have to uninstall that installation first. If you just install manually or with DIM, without uninstalling the Daz Connect version, it will forever continue to use the Daz Connect version.
