file location?
tophandtophand Posts: 138
Hiya,
I purchased https://www.daz3d.com/neverhome this morning.  Can't find it anywhere in my content library. Installed using DIM.
I'm still kind of struggling as to what consitutes a prop and what is an enviroment in some cases. IE Granite Bedroom is a prop
  • This seems to be a very old prop. I think you might find it under Poser Formats > Props or Figures.
    You could also download it manually and see exactly where they put it in the zip file.
  • CGHipsterCGHipster Posts: 241
    You can go to the Dimm, and select "Details" under your installed tab to see where it was installed.  It probably is in your Poser content as Illidanstorm has mentioned.
  • tophandtophand Posts: 138
    Thanks!!!   Got it
