Grouping all my custom morphs by categories
Having made a lot of morphs with Morph Loader Pro, I'd like to group them in separate folders by categories.
All my morphs are dialed from Parameters tab->Morphs->Morph Loader.
Actually, all the .dsf files are in C:\Users\Public\Documents\My DAZ 3D Library\data\DAZ 3D\Genesis 3\Female\Morphs\MyName\Product
I tried to create folders in this location and manually move some morphs in them. However, they all stay grouped with the others at the same place.
How to proceed?
You can chnage an individual morph by clicking the gear icon on itss lider, selecting Parameter Settings, and editing the Path. You can also edit the path in Morph Loader Pro. To set a number of morphs to the same path, right-click in the parameters pane and out it in Edit mode (if it isn't), then you can seelct your morphs with the standard click/shift-click/ctrl-click methods, then right-click>Set>Property Group. You will then need to save the moprh assets again, using the same options, to update them (or just save a scene or Character preset and use that to load the figure).
