Script to strip morphs out of a pose?
JQPJQP Posts: 527
edited August 2018 in Daz Studio Discussion
Morphs often make poses unusable. They can be really hard to find and zero because they get lost in the shaping morphs I DO want used, and often the text is greyed out, making them even harder to ferret out. Anyone know a script or something to help with this? A script to zero any morphs used in the pose just applied would be good, or a script to zero any morphs not memorized (that way I could memorize just before using the problematic pose), something like that, would not go amiss.
Post edited by JQP on
  • What do you mean? I'm not clear, sicne first you say you want morphs removed and then you want yours left. Also, you mentioned greyed out morphs - those are hidden (you presumably have Show Hidden Parameters on in the Parameters pane option menu) and many of them will be morphs that are designed to turn on in response to posing, to improve the shape, so zeroing them would degrade the appearance of the figure.
  • cm152335cm152335 Posts: 421
    edited August 2018
    no need script for a basic feature in DAZ menu
    use menu,, >> Edit > Figure> restore >  "restore figure shape"
    it redo to default shape or 'user' morph (in case you use the 'memorize figure shape)
    in case you use several time the feature, une "custom action" and place in toolbar of your Daz
    also, if you use extended morph, remember to apply Rigging "Adjut rigging to shape" that help for poses (also in Daz menu)
    Post edited by cm152335 on
  • 5200north5200north Posts: 249
    I don!t understand what your comment was about using extended morphs and adjusting the Rigging could you expand you re reply, it's the first I've heard of this
