Is there a tool or plugin to make poser save cr2's in a legacy format?
invisigothinvisigoth Posts: 155
edited December 1969 in Poser Discussion
I really dislike asking these questions,it makes me feel as though i am bothering people
anyway
does anyone know if there is a tool or plugin to make poser save cr2's in a legacy format?
i want to save my creations in a version 5,6,or 7 format,
i started using poser, since version 4..before pro pack,and most of my runtime files are compatible with poser 5 on up
i build custom characters,in poser,then setup scene and render in Carrara
since poser 8 crashes so much on me,i want to get used to the poser 8 characters Alyson ..and the guy (don't remember his name)
and though carrara reads poser format..poser 8 people faces are frozen..even if you save them with a expression,carrara opens them up with default face
  • Richard HaseltineRichard Haseltine Posts: 111,363
    Is Use external Binary Morph targets on in Edit>General Preferences>Miscellaneous? If it is, try turning it off and then saving the figure again for Carrara.
  • invisigothinvisigoth Posts: 155
    does that work in all versions of poser..i am thinking of upgrading to something more stable
    External morphs, stored in .pmd files, were new in Poser 5 or 6 - the preference has been in the same place since the feature was added, so yes the advice works in all relevant versions.
  • WandWWandW Posts: 2,907
    I never had any problems with Poser 8 crashing. Did you install the updates?
    http://poser.smithmicro.com/poser8updates.html
    First @ Richard Haseline..that worked for the face,thanks that helped...... but i noticed some of the body morphs dials don't seem to work for alyson..in carrara..
    somwhere in the transfer,her left breast became flat on the left side, I will see if the breast morph dials that i tried did anything in poser, before i complain lol
    @ Wandw....yes,i installed the updates,but have mainly been using 7..which i updated 2 days ago and it crashed too lol
    since i have a hard drive just for content, i have files going all the way back to poser 4 , so once i add something,i have to keep it
    anyway, thanx both of you....there was something i was experimenting with in poser 4 and it always looked funny when i rendered it
    the other day i saw the image,and wondered how it would look now,with my improved skills,and rendered in Carrara
    besides the flat breast,(i used a nude model just to save time) i was impressed by the render ... it looked better than what i did way back when
  • reko34reko34 Posts: 94
    I use poser 6 most of the time. Thougha warning jump out everytime a newer version file is read, I haven't found any real problem yet. I also use word/vba to remove sentences only used in newer poser and change the version mark to 6 because maybe reading rubbish raises the system burden.
    I'm not certain, but I think Alyson (like Victoria 4) uses magnets to adjust the breasts - I don't know how, if at all, they transfer to Carrara. I would guess they come across somewhat, of V4 wouldn't work, but that would be a thing to check.
    @ Richard.....they show up..but the dials didn't work (even poser waves and magnets show up if you open up a file that has them)
    I saved Alyson default, how you explained in your first post,..and all the sliders worked,give or take..a few didn't..but those don't work with daz figures either
