Resetting the point of rotation
will2power
Okay, this must be the day for questions. This has happened to me a few of times with props, and several times with a few figures. I've tried looking for an answer but I haven't quite found one yet. Sometimes, the gizmo for a prop or a figure will change its location from where it normally would rest --like clicking on a base figure it pops to the bottom or at least it should.
I've had the tool go off into left field on a figure or prop, making it impossible to reposition. I usually end up deleting it and then readding it to the scene when this happens, but I'm pretty sure if you can move it back to it's default position --I just don't know the steps to do it. Does anyone know how you reposition the gizmo on a figure or prop?
I'm using Daz Studio 4.6.0.18, by the way.
You can use the Joint Editor to change the pivot point...some information on that can be found here: http://www.daz3d.com/forums/discussion/3600/
