Couple Animation Questions.
First after saving my figure with Genesis 8 Alive animations my figure is no longer animated when I go to re import into the interface. Second how do I save my animated figure in DAZ Studio 4.10? Finally what settings should I be on when I animate figure as the camera zooms in and out and up and down! Any help would be appreciated.Cheers
  • How did you save the figure? I don't understand the camera question - cameras animate like anything else (note that the Perspective View doesn't animate at al, and isn't tracked for undo either).
  • Many thanks for your reply.I saved the animated figure as a scene subset.When I re introduced the figure into my interface the animations had disappeared! Whenever I make an adjustment to my animated figure for some reason my scene jumps all over the screen.Perhaps I should make all my tweeks while the camera in the perspective position! Cheers
  • I think I am used to Poser where the whole animation once made is saved as a PZ3. I have just gone and done my animation again and saved it as a Scene and a Scene Subject and again when I reimported back into DAZ Studio 4.10 all my Genesi 8 Alive Animations were not saved with my figure.I guess I am doing something wrong! Any ideas? Cheers
  • I would expect a Scene at least to work, and really a Scene Subset should too. I don't have Genesis 8 Alive, but it appears to be AniBlocks - if you have the full version of AniMate, rather than the Lite license inclided with DS, you should be able to bake the AniBlock(s) to keyframes - if you do that, does the animation then save?
  • csteell_c2893e4ab6csteell_c2893e4ab6 Posts: 537
    edited August 2018
    I have managed to save my animation by locking the frames in Animate 2.I guess I will have to read up on how to bake the Aniblocks.Cheers
    Post edited by csteell_c2893e4ab6 on
  • I have managed to save my animation by locking the frames in Animate 2.I guess I will have to read up on how to bake the Aniblocks.Cheers
