ANOTHER Measure Metrics problem.
So, today I started up DAZ as normal, and somehow between two days ago and today Measure Metrics once again has stopped working. The pane shows up and loads normally. Measure Metrics appears in my plug-ins and is green, with no box for entering the serial number (which was the problem last time it stopped working.)
But MM does not show up in my products list. If I search for "measure" only the Wearables for Genesis 8 appear. I need the Genesis 3 wearables, which have somehow disappeared. I tried uninstalling and re-installing, with no effect.
Any ideas?
Thank you
    Make sure you have a human model that it is compatible with selected in the scene tab & you should find in the Smart Content tab that it is listed under Utility
  • Note that this is Figure Metrics, not Measure Metrics. But there have been several posts about issues with its metadata, I've had oddities too, not sure why as Rob (the author) confirmed that it was set up correctly on the server.
