What can be done with Surface tags?
SnowSultan
in The Commons
Just curious, but is there a way to select surfaces by tags or any other way to utilize them other than the fairly useless search box that would only list tags you've selected already? I can't seem to find any other options using the Surface Selection tool or the additional options box in the corner of the panel.
Thanks in advance.
I'm not sure that there's much more to it, other than the 'All Objects' option. The tag selected is the one your mouse is over, but it would be better if we could have a list of all tags and choose from that.
I always fill in the tags for every material, but to be honest, it's a pretty thankless task, and I sometimes wonder if anyone ever notices, or uses them.
Thanks very much. I noticed MEC4D also uses them in her shader sets but as you well know, that's a lot of work to put into something that doesn't appear to have any practical uses so far.
I use them! So thanks ot all creators who do this. Mostly useful if you have to select stuff.
Thanks! Glad to hear it's not a waste of time!
Actually, I started out in Iray studying MEC's shaders, and that was what prompted me to fill in the tag field.
It's not that big a job. It's just that I generally have 30-40 prop in a pack, all with multiple materials, so the number can be high. But I just fill 'em in as I go along. It's no worse than doing all the thumbnails and tip images.
Paintbox, can you tell me how you use them in selecting stuff? I haven't found them all that useful for selection, but maybe I'm missing something.
Just use the tag filter to quickly find the material I want to select (edit)
Ah, the 'select surfaces with the tags...' option wasn't showing up when I was right-clicking on surfaces until just now. Now I see where it could be useful. Thanks very much.
Not as impractical as all that, IMHO. If I'm bouncing between shader options, trying to settle on a look I like, the tags help remind me of what material I've already applied. This is especially a Good Idea™ in cases where the material doesn't show properly until I render — e.g. I have a bunch of shaders in various folders that all look black in the Viewport, and my current system can't really handle using Iray preview.
Exactly! It's also really nice when I think to myself "I'd like to use that cloth shader I used last month..." I may have the scene file, but unless the tags are filled in, I'm never going to remember which of my 1400 Iray cloth shader presets (no that's not an exaggeration, I just counted them) I used on that image.
