how to syntax a morph preset ignore the scaling?
MistaraMistara Posts: 38,675
what the syntax to call a morph (for example Victoria 8) but not call the scaling in the morphs dsf file?
thanks.
  • What do you mean? Edit to remove the ERC?
    there's sections in the morph dsf, under one id
    the delta info
    the scaling under formulaes
    i can't find a syntax example to point to the id, but only look at the section with deltas
    do i need like a # in the statement, braces, etc?
    baically, how to point to a section grouped under the same id?
    for myself i just duplicate and delete the scaling i don't want.
    trying to make a legal distributable,  so can only call the existing morph dsf, but parse it.
    cant find anything in the json literature.
    i see how to create a morph alias, but it calls the whole dsf.
  • I still don't understand what you final aim is, and I'm not sure I know the details of the format in sufficient detail.
    there are characters that dont give a dial without the scaling.
    i want to create morph alias presets for those characters (like V8, Leo 7)
    that will syntaxically smiley call the deltas, but not call the scaling formulaes
    i dont mind manually typing, but i need an example.
    the pointer is a a url, dunno what to put after the url to call a section from within an id
  • You coudl always click the chain icon on the scale slider to disconnect the ERC. If you edit the base asset files they will be unedited by the next update.
