Refreshing DAZ between several opened sessions
I have several DAZ sessions open at the same time. This helps with my workflow.
Now, if I save a morph (created with Morph Loader) in a session, is there a way to refresh another already opened session, so the morph shows in the directory where it was saved?
Regards,
If you mean a preset, just right-click on the folder and select Refresh. Having two versions of DS (from the same release channel) open at once is not, however, a good idea.
Otherwise said, If I have two DAZ windows open at the same time, and I use Morph Loader to create and save a morph in one of them, how can I refresh the other one so my morph is available?
Did you save it as a morph asset? If so use a Character preset for your current shape/materials to refresh the figure - it will, by default, ask if you want to apply the preset to the seelcted figure which will load the new morph asset. If you don't get the dialogue, the options for how to handle Character presets when a matching figure is selected in the scene are in Edit>Preferences>Content tab.
