Realistic Bulge
Hi all. How do you get realistic "crotch bulge" from michael 7 etc? Is there a product for this bc I could not find one. When Miachael 7 is in boxers it does not look realistic at all with nothing there. Any insight appreaciated, thanks!
  • BeeMKayBeeMKay Posts: 7,019
    edited August 2018
    There's a good product over at Rendo: https://www.renderosity.com/mod/bcs/sy-pants-masculinizer-genesis-genesis-2-genesis-3-males/118722/
    Sickleyields Pants Masculinizer.
    Other than that, there should be a "bulge" in the hip region of the shaping tab that comes with the base character morphs.
    Post edited by BeeMKay on
  • BeeMKay said:
    Thank you. Did not see a bulge preference however.
    648 x 1056 - 93K
  • vwranglervwrangler Posts: 5,055
    edited August 2018
    It's not going to be in the Scene tab with all the bones, which is what your attachment shows. It's going to be in either the Parameters tab or the Shaping tab, under the hip region. (Either one should work; I usually use the Parameters tab for that.) Alternately, if you've installed the Genesis 3 Head and Body Morphs, you can just select your character, then search for the word "bulge" in either tab, and they'll be in the results list.
    Post edited by vwrangler on
  • CGHipsterCGHipster Posts: 241
    edited August 2018
    The instructions of where to find the morph can be found in the zip file, there is a readme. You will find your morph in the parameters tab, it is slightly different for Genesis 3 models than Genesis and Genesis 2.
    For Genesis and Genesis 2 it is under Parameters, Actor, Lower Body, Hip, Real World -> Pants Masculanizer
    For Genesis 3 it is under Parameters, Actor,  Hip, Real World -> Pants Masculanizer
    May your men be manly.
    Post edited by CGHipster on
  • OminousAutumnOminousAutumn Posts: 405
    edited August 2018
    I guess it must be something I still need to purchase. The head and body morphs for Gen3. Id like to avoid buying G8M. FOr some reason it wont let me attach another photo. on Parameters Tab under hip there is no bulge option. I only have a cornea bulge option for all of G3M.
    edited August 2018
    Hi Vanishot, the most realistic pants projection for the best price is "Pants Masculanizer", the price is good and it does what it says, makes your men more manly ;)  I misunderstood and thought this is what you had, I thought I saw it mentioned above.  The nice thing with this product is it can be used with Genesis, Genesis 2 and Gensis 3 all for under 10.00 so its truly a bargain.
    edited August 2018
    Cheers my friend!
    Yes, the Head&Body morphs for G3 give you some needed basic morph functionalities.
    edited August 2018
    Right on thanks!
    Edited to fix quotes
  • If you want to put your reply before the quote, like this, you need to hover your mouse at the top of the reply box until you see a dashed red line, with a red box containing a white arrow on the right - click the box and you will create a blank line outside the quotes for your words.
    Right on thanks!
  • PetraPetra Posts: 1,157
    Thank you so much for sharing with us.
  • DDCreateDDCreate Posts: 1,424
    edited August 2018
    Just out of curiosity, does anyone know to what extent the Masculinizer Morph works? I know in some clothing products that have morphs, the pictures won't always show examples of ALL of the morphs. Especially the more "racey" ones. So i was curious if the effects shown in the product page were all of the achiveable effects or if they "extend further" than what is shown.
    Post edited by DDCreate on
    I decided to go for it and buy it. But I can't locate the morphs inorder to apply them to the pants. (see attached) Does anyone see what I'm doing wrong? I'm 99% sure I installed them right. The only thing I can think of is that the instructions said
    "Specifically, this product contains a folder called My Library.  You must copy the files from this folder INTO the folder called My Daz3D Library."
    But the .zip file didn't contain a folder called My Library. Just Data and the read me text. I looked in the Data File and didn't see My Library either.
    1402 x 371 - 66K
    The data folder goes in your Daz Studio content directory - e.g. My Daz 3D Library or Daz 3D\Studio\My Library - where ti will merge with the existing Data folder (Mac users have to be a bit more careful and manually merge the corresponding folders)
    I did it the same way I do all my manual installs. I opened Data and it had sub-folders. So I drilled down correspondingly in My Library file and placed them. data>DAZ 3D>Gen2>Male>Morphs ect...
    edited August 2018
    Looking at your screenshot, you are not looking for the morph in the correct spot for the projection morphs, as these morphs are not found in the clothing but rather under the figure itself, under Actor, this is a projection morph.
    Go to parameters and select your figure (Character), then under "Actor", and the rest is explained in my original post.  You can follow the below images I took for this example, the first is Gen 2 and Genesis is the same, second is Gen 3, it has a slightly different path.
    I installed the morphs using an installer that I found on sharecg, "daz content installer", I know the installer works for pc I don't know if it works for mac, but if you like I can check my folder and see how it installed.
    Here is a link to the installer which I think is perfect if you buy or use 3rd party content from zip files: https://www.sharecg.com/v/71453/gallery/10/Software-and-Tools/Daz-Content-installer-from-Zips
    Thanks CG Hipster! I had it backwards. Appreciate the tip
    No worries, glad you are sorted ;)
