DS4.5 startup log - WARNING: dzvalentinaobjectdatabase.cpp(36): DB Fetch error: ... ???
3dcheapskate3dcheapskate Posts: 2,732
I've just noticed that I'm getting the following error (repeated around a hundred times) at the end of the logfile when I simply open up DAZ Studio 4.5 Pro (64bit)...
WARNING: dzvalentinaobjectdatabase.cpp(36): DB Fetch error: "FILE: ..\..\sources\VKernel\Fbl\prot\Structure\VarChar\FBL_VarCharFile.cpp FUNCTION: fbl::VarCharFile::BinarySearch LINE: 497" Varchar data "" is corrupted.
Doesn't seem to be causing any obvious problems, except when I'm using the ShaderMixer shadowcatcher and ShaderBuilder light in my worldball.
I'm guessing reinstall DAZ Studio? (probably should upgrade to 4.6 anyway...)
  • SimonJMSimonJM Posts: 6,106
    I believe a later version of the ValentinaDB is supplied with 4.6 which may help.
