Zurie issues with Classic Side Part Hair
Okay, I've run into a very odd situation. I purchased Zurie, without Zelara (not a fan), and she turned out great in the preview. I used the Classic Side Part Hair and the preview looked great. So I started the render and watched some TV while I waited. Sorry, but my graphics card doesn't render that fast like others here.
Anyways, the oddest glitch appeared on Zurie and her hair line with the Classic Side Part Hair that wasn't showing in the preview. I have a nVidia 1050ti that I use for the preview display and the final render. I also removed Zurie from G8F and did a render without Zurie. The render showed up just fine without Zurie, so the problem has to be Zurie to some degree. I checked smoothing for the hair and tried it with it on and off, with increased smoothing and collisions, but nothing changed the final render on Zurie.
Anyone know what could be going on? The image below has Zurie on the left, showing in the preview in the middle and G8F without Zurie on the right.
1080 x 720 - 111K
  • PetraPetra Posts: 1,157
    edited August 2018
    I just loaded Zurie and the side part hair and it looks fine after rendering. Not sure what causes the issue for you, hope someone can help.
    I do have Zelera though, but, that should not make a difference when it comes to the hair.
    The first image is Zurie Viewport, the second one rendered.
    876 x 1039 - 2M
    1200 x 1500 - 2M
    Post edited by Petra on
  • MacSaversMacSavers Posts: 324
    Well, I was excited to use Zurie, but I can't seem to get the Classic Side Part Hair and Zurie to play together unless I have the headlamp on the camera working. I never use the headlamp, so guess I'm out of luck.
    I never use the headlamp. I do not understand why they hair wont behave for you.:(
