using photo shop
1234MATT1234MATT Posts: 223
edited August 2018 in Daz Studio Discussion
i used "celia" texture maps and thought i would darken them up a bit in photo shop. i applied the torso and it looked great,,,i then applied the limbs and it looked great but the torso dident match any more....i just had phsp do a contrast "auto" to both and they are different...?help?
Post edited by 1234MATT on
  • Cris PalominoCris Palomino Posts: 13,050
    Auto can possibly give you different results as it's judging on a case by case basis. You should do it manually and use the same values for each map.
  • cm152335cm152335 Posts: 421
    edited August 2018
    best use in IRAY instead to use photoshop
    try first "SURFACES" changes
    select "surfaces" of character and unlock/unhidde  "DIFFUSE STRENGH" and in parameters setting of the "diffuse strengh" uncheck the "USE LIMITS"
    change "diffuse strengh" from 1.0 to 2.0 or more
    - in some skin it need to go more than 2.0 up to 6.0
    - after increase all surfaces just correct the mouth diffuse strengh,,, a bit lower than surface skin
    Post edited by cm152335 on
  • 1234MATT1234MATT Posts: 223
    ok i think i get it,,,i had tryed layered imade editor but it has changed from how it used to be,,,i will try the unlock thing , i know how to do that,,,really much thanks for the help on this.
  • ForceXForceX Posts: 52
    edited August 2018
    If you are going to use photoshop don’t use the auto correct you will never get the same adjustments across different images. Instead use the layer adjustments like brightness & contrast, exposure, color correction, ect. When you get the look you want you can simply drag and drop them from one image to the other.
    Post edited by ForceX on
    Note if all you want to do is make the skin texture darker, you can also do it from the surfaces settings. If the skin has a texture map and the color is set to white (255, 255, 255), then change the color to a lower value (128,128,128). The color is multiplied against the texture and since the original texture files are balanced contrast wise, changing the color value to a darker shade of gray for all the skin surfaces will uniformly make them all darker.
    Another way is to click on the texture image as if you were going to browse for a new texture and choose Image Editor. There you can adjust the gamma of the image without changing the texture files themselves.
