PP2012 -> 2014 migration?
Lissa_xyz
I bought and installed the PP2014 upgrade, and it appears to have given me pretty much a full install with a full serial (I assumed it would look for and overwrite my existing PP2012 install). It even greyed out the box for my previous serial once I launched PP2014 (where it says 'if this is an upgrade please provide your previous serial, etc).
Now, here's my setup:
E:\Program Files\Poser Pro 2012
E:\ Program Files\Poser Pro 2014
Is there an easy way to migrate my saved render presets, general prefs, etc from 2012 to 2014 without messing anything up? I was unable to find some sort of migrate presets option. I suppose I could just open each on separate monitors and just copy them over manually if I had to.
Also, does DSON require a whole new install, or can I just copy the scripts over from my 2012\runtime\python folder?
/edit
Nevermind. I copied over the python scripts that I had manually added and reinstalled DSON to the new Poser install. I'll just redo my render settings.
