How to import other file without error message?
Hello, i try to import files exported from ViaCAD Pro 10 as .obj, .dxf, .dwg, .ai, .3ds, but every try i achive warning "Read error". Same files is reeded by DAZ Bryce Pro 7.1, (.obj very good, others 'some like').
Please, give me some tips.
zip
zip
08_3otwmultitool.zip
139K
  • Which version of Hexagon on what O.S. ?
    With Hexagon(beta _ 2.5.2.137) on Windows, the obj file loads without error.
  • AscaniaAscania Posts: 1,856
    Works fine in 2.5.2.109 too. Might be the missing .mtl file
    Can you post a screenshot of your import dialog? Some of these tickboxes won't cause an actual error if they're not set right, some can cause Weird Stuff™ to happen.
  • One issue with the model is that its surfaces are dissociated. You want to export the model as a solid volume mesh.
