PandoraX
phoenaphoena Posts: 12
Recently picked up the PandoraX, but all it will seem to do is change the body texture and shape. NONE of the clothing items will fit to the body without intense manual reshaping. Even then, the clothes won't move with the body. Is there a way to make the clothing fit properly?
I have DAZ 4.6
Victoria 4
and all that those come with....
Please help me out here.
    Have you "fitted" it to Genesis ?
  • phoenaphoena Posts: 12
    How do I do that? I am very new to this program.
    I think I have the auto fit tool already installed, but nothing like the tutorial video ever happens.
  • Richard HaseltineRichard Haseltine Posts: 111,013
    edited August 2013
    To fit clothing select all of the items and then in the Parameters pane click the button under Fit to, then seelct the target figure (such as Victoria 4).
    Could you post a link to the product you are using? The only Pandora X I can see doesn't include clothing - or is the problem that you can't get other clothes to fit the Pandora X character? if so, right click on the figure after applying the shape and fitting the clothes and select Transfer Active morphs from the menu.
    Select the clothing item in the Scene pane or Viewport, right click, and select the 'Fit To' option. You can also select the clothing item in the Scene or Viewport, the go to the Parameters pane and select 'Fit to' from the General option.
    If Autofit does not pop up immediately when you load the clothing, Fit To will cause it to appear.
    edited August 2013
    http://www.daz3d.com/pandora-x
    http://www.daz3d.com/victoria-4-3d-model-pro-suite
    If I use the PandoraX pose (not sure why its a pose for the body style and not a material/morph) nothing fits. Also, this can't be fitted to any Genesis models. But the Victoria clothes don't fit on Victoria after she has assumed this pose. Is it possible to "fit" the Victoria body to a Genesis character? I have tried doing this as well but it crashes DAZ.
    I've edited your post to link to the product pages, the links to the Product Library pages won't work for people who don't have the items in question.
    You need to try the Transfer Active Morphs step I mentioned above - after editing my post so yu won't have had it in the reply notification - to get teh clothes on V4. Morphs don't automatically transfer to another figure - you can use Gen X to do that, or do it via the transfer Utility, but it is a little fiddly.
    Richard,
    I have tried both the transfer active morphs (which seems to do nothing) and the Transfer Utility (which won't let me select anything in the drop down menus). What is the Gen X you are referring to? I did a search for it but only found a clothing item.
    edited August 2013
    http://www.daz3d.com/genesis-generation-x
    Which is for Genesis only. It won't work with V4.
    Post edited by Chohole on
    But I would be able to take all of my V4 content and turn it into compatible Genesis stuff correct? Will this allow the same amount of morphability with the Genesis character that is offered by V4?
    Pandora won't work on genesis, that morph set is V4 only.
    If you use GenX on Genesis you also need http://www.daz3d.com/v4-and-m4-shapes-for-genesis
  • JaderailJaderail Posts: 0
    edited August 2013
    Read this from the INFO for PandoraX.
    If you wish to use clothing from the DAZ store with the included PandoraX body morph,
    I have created a website full of fit-morphs available for free download.
    You can access the website here -PandoraX-.
    You need to VISIT the Site to get the Clothing Fits.
    Post edited by Jaderail on
    edited August 2013
    You assumed Genesis. The OP stated Victoria 4 in their initial post.
    I think you confused the OP by bringing Genesis into the mix. They were initially having issues with V4 and fitting clothing after applying the PandoraX body shape.
    Post edited by Lissa_xyz on
    Thank you Jaderail, this is a little more work than i'd like to do but it works perfectly for PandoraX. Now if I make a duplicate cr2 file for each piece of clothing, will I have two different options in the content library to choose from? This way I can make one for the base stuff and one for Pandora? Or will this auto adjust?
    Most clothing fits are pz2 injection files for the clothing itself. You could possibly save out a duplicate CR2 after applying the injection to the clothing. Just be sure to name it differently as to avoid overwriting the original clothing (something like ClothingName_PXFit or something).
    edited August 2013
    Not me. I only explained that GenX was for Genesis, after it was mentioned. :roll: and then answered the follow up question. :coolsmirk:
    I do recommend, however, that the OP come over to the New Users Help Forum, where we do have people around who can guide him through all his starting up problems. http://www.daz3d.com/forums/categories/97/
