What is happening with these limbs?
You've updated the software and now the model's legs look terrible. What is happening?
1440 x 1152 - 1M
1440 x 1152 - 1M
1440 x 1152 - 1M
Check out this thread:https://www.daz3d.com/forums/discussion/270476/too-much-liposuction#latest
Thank you
This is a bug in the current DS beta release. As a work around you can select the figure then select Currently Used in the Posing Tab and you will find two morphs called Flex Quad Left and Flex Quad Right have been given rediculous values. You can change these manually, or when the pose is applied select the "Leave limits on" option. See attached image.
There is another thread with this, I think this is awesome! Get those creepy renders finished before they fix it lol.
Would make good zombie morphs! You can always dial up (or down) the Flex morphs yourself, even after they fix the bug :)
