How to install DSON with DIM?
Sorry if this is a dumb question. I've forgot how to set up DIM to install the Poser DSON. I have P10 & P11 both installed & have the 32 bit of both but the 64 bit for 11 also. I forget how to direct DIM to install DSON to the correct Poser programs. Also can I use DIM to install DSON to both versions of Poser? I had to redo my comp a bit back or I'd a had this still done.(That's kinda why I can't remember how to do this). I did a forum search but I didn't find anything.
  • Click the gear icon at top-right i DIM to open preferences, go to the Applications tab, click the + to add an applications, set its details, and click the ... button to locate the folder. For the DSON Importer I think you will need to tell it that your version is actually 2014/Poser 10. I've never tried isntalling to multiple copies of Poser, but if all are in the Applications tab I think it would work.
  • Guardian Angel 671Guardian Angel 671 Posts: 231
    edited August 2018
    I got it installed into p10 for the 32 bit. The 64 bit won't go into the 64 bit of P11 but I can live with just P10 having it for now:) thankies Ok I think I finally got it into the P11 64 bit. :)
    Post edited by Guardian Angel 671 on
