Generation X2 MIA
jim_doria
Still in the process of setting up my new computer, I went looking for Generation X2 in Daz Studio 4.10.
It's not showing in the Panes tab. So I read the manual:
In some cases, GenX might be missing in the main menu of DS4. This may happen due to
menu customization. In that case, use Edit/Customize from the main menu and add the
GenX entry on the left side under Panes to the main menu on the right side. It also helps
usually to select a different layout or reset the current layout for the workspace.
So I followed these instructions (it's Window / Workspace / Customize now) and tried to find it in there.
It's not showing up anywhere.
Uninstalled. Re-installed. Re-installed using the downloaded files instead of install manager. Changed to different layouts as also recommended.
Any idea where I go from here? I'm missing my X2. :`-(
Have you entered the serial number?
Goto Help/About Installed Plugins & check that Genesis Generartion X2 is enabled, If not then Enable it, Close & Re-Start DAZ
@Richard No, didn't enter S/N because I couldn't find where to do that.
@Platnumk Thanks for showing me where to do that!
All set up and working now, so muchos gracias!
Glad you got it working
