genesis generation x2
rok405rok405 Posts: 0
Hello everyone, i can t select Source , besids Genesis , but i have other versions Genesis too, can someone help me?
Can t drag and drop too.
Post edited by rok405 on
  • MelanieLMelanieL Posts: 7,865
    Two points here:
    1 - Have you bought the add-ons for GenX2? The product itself comes with support only to transfer between Generation 4 (i.e. Victoria 4, Michael 4 etc) and Genesis.
    To add support for Genesis 2 figures you need this as well: https://www.daz3d.com/genx2-addon-for-genesis-2
    Then to add support for Genesis 3 figures you also need this: https://www.daz3d.com/genx2-addon-for-genesis-3
    2 - There is no support for Genesis 8 figures - the creator of GenX2 and it's add-ons died some time ago and it has not yet proved possible for anyone to extend the product to Genesis 8.
  • rok405rok405 Posts: 0
    MelanieL said:
    Two points here:
    I bought that https://www.daz3d.com/genesis-generation-x2
    it work between all versions genesis..
    edited August 2018
    Sorry but it only works between all versions if you have the add-ons - here's the relevant part of the product page:
    819 x 769 - 150K
    Post edited by MelanieL on
    Oh my gosh.. Thank you for help, i m still sittin more than 7 hours over this issue, can u give me link what i m need bought now?
  • algovincianalgovincian Posts: 2,696
    edited August 2018
    It should be noted that, unfortunately, the author of the utility passed away some time ago and there is no Genesis 8 support. Sorry, just read @MelanieL's post more completely to see that this has already been mentioned.
    - Greg
    Post edited by algovincian on
  • Kev914Kev914 Posts: 1,143
    I decided to finally get around to messing with this product. I have GenX and GenX2. I have installed GenX2 but not GenX. There are two serial numbers in my account that say Genesis Generation X. There is no serial number that says Genesis Generation X2. I tried both serial numbers and Daz seems to be happy with either. I restarted DS and I now have a GenX panel. It says GenX, not GenX2. Should it say GenX2. Maybe I need to try the other serial. I checked and I do own both. They both say purchased.
    If the GenX panel is OK, then I'm not sure what I'm doing wrong. In the video I watched they dragged M4 into the large panel under morphs (I think), and then some things loaded. Then they dragged the injection morphs into the same window and they loaded. I want to convert a character from Genesis 2 to Genesis 3. I started by dragging Genesis 2 Male into the window, but nothing happens. I also tried dragging Dusty...the character I wish to convert but nothing happens either.
    There is a LOAD button, if I click on it, the only file type available is a Cr2. Does this product only work with Cr2s?
    I own all the addons as well for GenX2. I have not installed GenX or the the addons for that product. I think there were two, but maybe I'm mistaken about that. In any case, they are not installed. I think I read that you should not install GenX and GenX2. But perhaps I'm wrong on that too.
    Thanks.
    Well, I guess I figured part of it out. There was a dropdown near the top where you select the figure. I chose Genesis 2 Male and set the output as a Genesis 3 male. Then I loaded a pose and picked the head and body for the G2M Dusty. I used control click to apply them both at the same time. (Maybe you can't do that?I set the other settings according to the video. I wanted one morph to load the body and the head. Or should I have a separate morph for the head and the body since that how the G2M character was set up. In any case, it ran and now I have one shaping morph for Dusty when I have genesis 3 male loaded. When I dial it, I can see it changing the face, but I'm not really noticing the body change.
    In the video, he set set set the V4 morph for Genesis to 1 and then set the morhp for Scarlett to 1 (that was the figure he transfered.
