'2b Nier automata'-like hair
Hi im looking to render an automata 2b scene. im having problem looking for a similar looking hair for 2b and A2(if possible). anyone can point me to right direction? thanks!
    The closest I can recall is this one : https://www.daz3d.com/jette-hair-for-genesis-3-and-8
    But then again I'm not really into the art style, so Im sure someone else will chip in with something better... good luck finding though. It's really nice if you find something you were looking for.
  • There's an outfit and hair called "Android-47" available at Renderotica, which I assume is exactly what you're looking for. I'm not sure if it's ok to put a link to that site because of it's adult content, but if you go there and type "android-47" into the search box at the top of the page, you'll find it. It's for G3F, so should autofit to G8 easily enough.
  • HaruchaiHaruchai Posts: 2,040
    edited August 2018
    The outfit is also available at the artists own store page if you don't want to frequent Rendererotica (guhzcoituz.com)
    Here's how the hair renders. I changed a couple of things on the outfit FYI but the store thumbnails will show you exactly what the rest looks like.
    A2 is an import of an MMD model but wearing Long Shag Hair. Again for G3F but should autofit with no problems if you are using G8F.
    https://www.daz3d.com/long-shag-hair-for-genesis-3-females
    1920 x 1080 - 1M
    Post edited by Haruchai on
  • videoninja719videoninja719 Posts: 344
    edited August 2018
    thank you. both the characters you rendered looks great! i didnt know you can import MMD models into DAZ. i guess i should try that sometime. thanks again!
    Post edited by videoninja719 on
    thank you for the info. i must have missed the part where hair is included.
    thanks for the wish. The hair you linked looks fantastic as well. already put it on wishlist. Thank you!
    There is probably a long way round to do it, via Blender etc, but I use a MMD importer that imports directly into Studio. Unfortunately the file is no longer available.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,645
    yeah that script was awesome
    the other way is collada export and dicey at best, have no idea why the OP pulled it
    edited August 2018
    i have purchased the sets from the site you linked. however im getting dark-skinned colored 2B from my renders. even darker than the one in your render, the genesis 3 female(victoria 7 in my case) skin im using is fair but when the outfit is on it turned out dark-skinned. is it supposed to be that way?
    Not sure how the outfit would affect the skin, there are no Geoshells in it and that is the only thing that would cause the skin colour to change that I am aware of.
    As I mentioned in my post the are some other things going on in my image. Guhzcoituz has a face morph and a face texture for 2B on his/her Deviantart account -
    https://www.deviantart.com/guhzcoituz/art/2B-Face-For-Genesis-3-Female-695299046
    The texture matches Aiko 7. Aiko 7 materials are applied to G3F and then the face texture is applied manually to the diffuse cannel via the surfaces tab. This is probably why my character texture looks a lot lighter than the V7 one you are using. The face morph is called '2B face' and is manually dialled in once the file is put in the data folder.
    The stockings can be found here
     https://sharecg.com/v/90870/gallery/21/DAZ-Studio/Geoshell-2B-Stocking-For-Aiko-7
    I found the original stockings to be too baggy around the thighs so I made some based on Forged3DX's work. The setup and links are in the ReadMe.
    Guhzcoituz's outfit textures are actually based on the original XNALara/MMD rip. I found a 'clean' version of the model and used the textures from that for the outfit textures which is why the boots in my image will appear less muddy that you will be getting.
    If you need any more help let me now.
    BTW I found a 9S as well (MMD import again) :)
    1920 x 1080 - 3M
    Thank you @Haruchai for pointing me in the right direction. Great to know you found 9S MMD for daz. i think i might stay off playing around with MMD models for now and stick with DAZ models due to my skill level. Been using Daz for a few years not but still not a pro at it. Got another question if you have the time @Haruchai. I have installed the 2b Face morhp into 2b and dial it using the parameters shaping. But im not sure how do you put in the skin texture? is it just toss in the texture inside the icon of face in the shaping dial for base shape? replacing the victoria face texture? thanks
    edited August 2018
    No worries.
    You need the Surfaces tab not the Shaping tab.
    If you have them apply the Aiko 7 materials to G3F.
    Open the hierarchy of G3F within the Surfaces tab until you get to 'Surfaces' (I loaded Aiko 7 straight off but the method is the same).
    Click on Face to turn it yellow (picture 01).
    In the base color (or diffuse color if you are in 3Delight as G3F loads) left click on the little face image and a dropdown list will appear with the currently selected texture ticked (picture 02).
    At the top of that list click on 'browse' and browse to where your 2b_face texture is, mine is in the Andriod47 folder in Textures in the Runtime to keep all my 2B textures together (picture 03).
    You should then have the 2B face texture applied to G3F (picture 04).
    Your image may look different if you don't have the Aiko 7 body textures etc loaded.
    If you want any more info please ask. I get what you say about 'skill level' but everyone I have ever encountered in this Forum has been more than generous with their time, knowledge and patience. Post a thread if you want to know how to do something, someone will know and explain. I have been here since 2006 and I still post questions :)
    649 x 801 - 126K
    652 x 854 - 147K
    1025 x 800 - 170K
    946 x 839 - 172K
