morphing problem
I use Minami and youth morph at growing up and this chin makes me trouble. any suggestion to get rid this chin thing?
1018 x 828 - 2M
1019 x 881 - 904K
  • Cris PalominoCris Palomino Posts: 13,050
    While we morph makers make every effort to make morphs blend, you will find some that just can't. You can alleviate it, at times, by using lower percentages of the morphs. What percentages is each morph set at?
  • kjino570kjino570 Posts: 39
    It was 100 percent. i try 20~100% and that chin is still looks like that. thought there is some other morphing tool for fix this or other technical issue.
  • You could try applying a Smoothin Modifier (Edit>Figure>Geometry>Apply Smoothing Modifier) and in the Parameters pane under mesh Smoothing set the type to Generic - but that may smooth details you want to keep unacceptably too, though you can experiment with the Iterations setting.
  • ForceXForceX Posts: 52
    If you have the ability export the model out to a modeling program ie Blender, ZBrush, Maya, Max, ect and create a corrective morph.
