Daz Studio, OBJ's and Rigging Question
Knight22179Knight22179 Posts: 1,195
Let's say I download a cool human-like model, but to my dismay it's in OBJ format and I can't pose it. Is there a way I could use Daz Studio to Rig the figure so I can pose it within the program? And if someone could point me to a in-depth tutorial that would be great.
  • DZ_jaredDZ_jared Posts: 1,316
    Yes, you need to use the Content Creator Tools that come with DAZ Studio 4.5 Pro. Here is a link to all the rigging documentation we have: http://docs.daz3d.com/doku.php/public/software/dazstudio/4/userguide/creating_content/rigging/start
    You're two most important tools are going to be the joint editor tool and the weight map tool. The former allows you to actually build your skeleton, while the latter is what binds the mesh to the skeleton.
    There is this : http://www.daz3d.com/rigging-original-figures-in-ds4-pro in the store here.
    By Blondie9999, it is about the most comprehensive tutorial you will find I think.
  • Knight22179Knight22179 Posts: 1,195
    Thanks, DAZ Jared and Jimmy. :)
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,712
    for a quick easy way you can use the transfer utility treating it like clothes.
    How would I do that without the ability to "Fit to"? Last I checked, you can't do that with OBJ files.
    oh yes you can
    (not fit to but rig to)
    get genesis as near in shape as possible to the object
    which has to be imported in default position to Genesis
    re-exporting is one way to do this
    then open the little backwards male symbol icon
    pick source genesis current, your obj as target
    tick use near vertices slide it right up
    you can also click on morphs and tick both boxes on right to add Genesis morphs
    then accept
    Transfer utility would be a great way to start, but you will probably still need to adjust your weight maps. The nice thing is you won't be painting your maps from scratch. To use the transfer utility make sure you have Genesis (or G2F if you'd rather) in the scene as well as your .obj file. Make sure they are close together, and line up as much as possible like Wendy said. Next click the transfer utility button (sort of looks like an arrow.) You need to be in city limits and it will show up on the right. Choose Genesis (or G2F) as the source and your .obj as the target. In the options make sure you have weights selected.
    Thanks guys, I'll have to give this a try! :)
