Mousso's Nylyssa
Fae3DFae3D Posts: 2,933
edited August 2018 in The Commons
So I just recently bought Mousso's Nylyssa.  She is GORGEOUS!  But I do have a question:
I can only use 3Delight (Iray doesn't work for me), and I know she is for Iray only, but I have a converter.  Not the one here, one from the "other" place, specifically for character conversion.  I use it all the time with great results.  She looks lovely in it, but she will only render in a human skin tone, with no eyeshadow, even when I've applied one of the "elf" skins and makeup.  Attached is a test render of her that should have had the green skin and pink eyeshadow.
Does anyone know if there is a way to make these options work in 3Delight?
Edited to add: I get the same result if I try using the Iray textures in 3Delight, no fantasy skintones, no eyeshadow.
3000 x 1854 - 7M
Post edited by Fae3D on
    Nylyssa is a lovely character. I seem to remember the textures being very large. Could it be memory?
    Are the textures there? what happens if you check out the surfaces tab?
  • Fae3DFae3D Posts: 2,933
    Just checked surfaces.  The base or diffuse color is apparently always this human fleshtone.  The only difference seems to be something called Translucency Color and SSS Reflection Tint.  On the face, there is also a Diffuse Overlay Weight with eyeshadow opacity, and a Diffuse Overlay Color of pink.  None of this means anything to me, I'm afraid.  But I'm guessing that these options don't exist in 3Delight, thus I can't use them?
  • you could use LIE, use the diffuse overlay map and a color.
    How would I get that into LIE?  I'm sorry, I've not really worked with anything like this before.
    Does anyone know if there is a way to replicate the Translucency Color and SSS Reflection Tint in 3Delight?
