Question about V4, V5, V6 anatomy and the Pro bundle
Kevin RyeKevin Rye Posts: 392
edited December 2015 in New Users
After a lot of research in the forum, it's clear that Victoria private parts are only available by purchasing the Pro bundle. However, I have a question as to what that includes. Currently I have a few textures that have privates on them, however, they are flat against the body. They do appear in the render, but as a flat image.
So my question is, what do you get by buying the Pro bundle in regards to privates? Do you get to adjust things like labia, etc.? If I want Genesis to look like she's smuggling a yo-yo, can I?
I don't want to spend $80 bucks and find out it's just a crease.
Anyone have some links to some images so I can see what's possible? (You can PM me if you're worried about posting them in the forum.) I've seen a lot of impressive renders on deviantart and was wondering if they were achieved with the Pro bundle or a 3rd party add on because they are extremely accurate.
Post edited by DAZ_Brian on
  • jaxprogjaxprog Posts: 312
    I purchased the Victoria pro 6 bundle and its pretty much the same flat image as you speak of.
    However if you purchase "shape shift" then you can morph that area to show mass or a mound as well as other settings to adjust the height or how wide it is.
    http://www.daz3d.com/morphs/shape-shift-for-genesis2-female-base-and-v6
    You can also use photoshop to draw/color the UV maps to give this part of the anatomy more character such a pubic hair.
  • Kevin RyeKevin Rye Posts: 392
    Cool. Thanks for the tip. I'm going to have to try and contact that guy on deviantart and ask him how he did it.
    V 5 and V6 use geografts, V4 doesn't as it is part of an older generation of figures.
  • Scott LivingstonScott Livingston Posts: 4,352
    I have V6 Pro too. It's not exactly a flat image and definitely not the same as the "base" figure with no genitalia. It's an extra part that attaches to the main figure to give the pelvic region a more realistic shape. You can use any skin texture on it, as long as the texture is compatible with the figure. Some textures have a more realistic or detailed pelvic region than others. But there are no morphs...from what I understand, it's the same with the V5 gens (I don't have that one). I suppose it's possible to make some morphs in a modeling program. Also, there are other stores out there (Renderotica, etc.) that have a greater variety of adult-oriented products.
    I agree Scott to a degree. There is gentalia on/off "switch" so to speak, however by turning it on and attaching, I am not sure that it is remeshing the genesis 2 geometry/topology to give it mass other than slapping a texture map over the anatomny giving it the appearance of someting more life like.
    I can't check at the moment, but as I recall there's an on/off option for textures, and a geografted part that (I think) shows up in the Anatomy section of Smart Content.
    Except for V4, whjch is a standalone figure and older, so doesn't use the gegraft technology which came with DS 4 and Genesis.
    So if I wanted to do more realistic renders, I should go with the V6 bundle instead of the V4 bundle?
    edited August 2013
    I came home for lunch to do this test of Victoria 6.
    I was little harsh on Victoria 6's gens. She has some form afterall with some topology.
    In the screenie provided the left or up front Victoria shows her without any modificiations... just simplly loaded and underwear fitted.
    The Victoria behind the front, the rear, I have made some adjustments to her crotch using the shape shifting product as you can see the slider controls on the right. You see there is a difference in depth and size over the Victoria in the front.
    So Scott you are right!!
    Ryemac I hope the helps to get idea what the shape shifting product is capable of.
    Post edited by jaxprog on
    edited August 2013
    Excellent. Thanks. That looks like what I'm looking for. So that's V6 Pro with the Morph pack? Or just what you get with V6 Pro?
    Post edited by Kevin Rye on
    The Victoria on the left or front is what you get in the pro pack. There are no changes to her form.
    The Victoria on the right or rear is modified using Shape Shift product that does not come with Victoria 6 pro, but must be purchased seperately.
    edited August 2013
    Perfect. Thanks.
    UPDATE: I picked up the Shape Shift bundle and it was just what I'm looking for. Just enough to make it so there's "something" there, but not too over the top. I wish I could post a pic, but this is a family show.
  • polmearpolmear Posts: 33
    This might be old news, but just a note for those who need (and notice)
    If you use Genesis 2's anatomy in Poser and you change any of the base figure morphs, like the legs length or what have you, you need to use the 'transfer active morphs' script to make them apply to the anatomy figure.
    Well, at least that's what I have found.
